manizee 0 points N/APosted on - 12/14/2011
I am very fan of playing games and i just find a game named as MOHA. when I am going to play this game, an error occurred that please change your color quality. what does this means?sort out my problem. As i want to play this game today.
Hello manizee, I want to provide you a solution that may solve your problem. I think your direct x software is installed in your computer. If not install the direct x software. On the other hand make sure that your PC hardware configuration is favorable to the game which you are trying to launch. Furthermore you can also reinstall the game. Before installing you should read information about game setup which is provided in the main folder of the game . I think you will launch the game after these operations. Thank you.
If you are new to computers no matter we are here to solve your each and every problem. You just need to follow some simple steps to make changes to your video and it will work perfectly. Please follow these steps:
Go to desktop and right click on desktop.
Then click the properties.
Once you are in properties then go to settings tab and see your color mode.
Once in setting tab you need to change the color quality form there.
You can change it to 16 bit or 32 bit as you require for your game to play.
You will be able to play your game. Some games supports 16 bit while others supports 32 bit.
If your “MOHA” game triggers an error when you play it and prompts you to change the color quality of your display, it means the game is designed to run on a particular display mode. The error refers to the display mode used by your desktop screen. In Microsoft Windows, there are two display modes or color quality you can select for your desktop screen: 16-bit and 32-bit.
16-bit is the medium color quality and the lowest possible setting you can select for your desktop display while 32-bit display mode is the highest color quality setting you can set for your display. If the game triggers the error and you can’t play it, see what display mode is being used on your computer. Click “Start”, “Control Panel”, “Appearance and Themes” then “Display”.
In “Display Properties” window, go to “Settings” tab then under “Color quality”, select a different setting like if it is set to “Highest (32 bit)”, click on the dropdown list and select “Medium (16 bit)” and vice versa. After this, click “OK” then try playing the game again and see if it works.
Lead generation and demand generation are two of the business strategies that help businesses grow. It creates a pipeline of interested customers looking to find out more. Lead generation on the contrary, is able...
1....
