Error running iMobile on iOS 5
As we know, iMobile is an application which we can avail in Apple App store. It is very useful for ICICI online banking and is properly working using iOS4. But after upgrading to iOS5 and tried logging in with iMobile, the application just keeps on crashing. Since then I stopped using the application again. But this is really useful for me so please help me fix this kind of problem. Thanks a lot!
Answered By 75 points N/A #101611
Hello Bella Coal,
So the problems with the iMobile crashing started after you upgraded from ios4 to ios5? Then it seems like the iMobile that you used on the ios4 is not supported on the latest version ios5 that you switched to. You may be needed to find another application that is supported by the ios5.
Otherwise you may need to contact the apple support and address the issue them, maybe it could be a temporary problem that can be fixed by the apple support. So just contact them and see if they will offer you a solution.
Hope this helps.
__
Regards
Lee Hung
