Error Running iTunes on Windows vista?
After installing iTunes on my wife’s laptop, which runs on the Windows Vista, I always get an error message every time the system resumes or boots up. I have looked all over the internet but it has not bore any fruit. If I may just go deeper, then this is the error message that is executed: RunDLL “Error loading winrrt32.rom”. Please what should I do to rectify this system error that keeps on appearing on my wife’s laptop?
Thank you very much and I will be looking forward to having a solution from you.
Best Answer by jenywhite
Answered By 0 points N/A #151755
Have you recently installed any new hardware?
This issue may be because you have installed a faulty hardware installation. Your computer is trying to load a rom file that is not on your Vista PC. Search your computer for this ROM file and delete it or check on the startup folder and remove it.
Answered By 0 points N/A #151756
Tonymathew0091, Unfortunately your not alone with your issue with the battery life for your new Galaxy Note. I would suggest that you let it completely died down until it turns itself off. The 3 – 7 days in a row if able and by doing this it the battery will calibrate itself and the life should increase. Then you can use the note as unusual ( charging tops ups on different devices such as car, laptop, etc.)
After that do monthly full charge to flat, and back to full.
Also whenever a battery gets too low it works to save the battery from being damaged and the 5 % is reserved. For cell reversal to happen which destroys the battery it has to become really exhausted. As I stated before this is a issue everyone seems to be having and at this time not even the customer service does not have answer to why this issue is occurring. I hope this help.
Hello Mr. Cunningham Stevenson, there are different downloads for different bits. Vista has 32 and 64 bits it just a matter of finding out which 1 your wife laptop has. You can find out by
click on start bottom (at the lower left side of the screen)
Click on system
Locate the System type 32 or 64 bit
If your system is 32 bits you will need to download the following instructions for security update' Microsoft Visual C++ 2005 Service Pack 1 Redistributable Package ATL Security Update before you can install the iTunes. By using this link http://www.microsoft.com/en-us/download/details.aspx?id=14431#filelist
  1. Click the download button
  2. Select run ( to start installation)
  3. Click save
Once you finish with this installation you have to make sure you have no other parts of iTune programs on the computer. Follow these instructions below:
  1. Clicking on start ( bottom left hand side of screen
  2. Select Control Panel
  3. Click Programs and features
  4. Look for iTunes ( if you see it)
  5. Click uninstall
Now after you have completely remove iTunes you should restart your computer you can now down load the latest version of iTunes click on these link https://www.apple.com/itunes/download/ and for 64 bits you will need the 64 installer you can by clicking on this link http://support.apple.com/kb/DL1427 I hope this helps!
