Error running PES 2012 on my HP 630
Asked By 7060 points N/A Posted on -
my PES 2012 wont run completely . When i am to create my avatar it always stops running at that point and when i restart it , its the same problem i face
Answered By 20 points N/A #83422
Hi, the video/graphic card you used  did not meet the requirement.  You have to create video/graphic that will meet the requirement by using 3D analyzer software. This piece of app will create from your RAM.  Just follow these steps: 1.  Select the .exe file of the game, in this case select pes2012.exe  2. Tick the features you want the app  to emolate.   Generally, HW TnL, Sw TnL and pixel sharers need to be check because they are the one responsible for the  game graphics.  You can experiment with different settings. 3.  Select the DeviceID and VendorID (copy and paste the ID's  given under Nvidia and ATI cards) 4.Save the batch file for future use with the same settings.
Answered By 590495 points N/A #278472
If you have problems running Pro Evolution Soccer 2012, you probably need to review the game’s system requirements to better check if your computer meets the requirements. Pro Evolution Soccer 2012 supports Windows XP Service Pack 3, Windows Vista Service Pack 2, and Windows 7.
pro-evolution-soccer-2012
It requires Intel Pentium IV 2.4 GHz or faster processor, 1 GB RAM, Microsoft DirectX 9.0c-compatible video card with 128 MB video RAM and Pixel Shader 3.0 support, sound card, and 8 GB free hard drive space. If you are using Microsoft Windows XP, make sure you are using Service Pack 3. You can download it from Windows XP Service Pack 3.
This is the latest and very last Service Pack upgrade for Windows XP. If you are using Windows Vista, you need to use Service Pack 2. Download it from Windows Vista Service Pack 2. This is also the latest and very last Service Pack upgrade for Microsoft Windows Vista. You may also try running the game with elevated privilege.
Right-click the game’s icon then select “Run as administrator”. See if this works.
