Error in Saving Topaz Adjustments
First of all, my primary problem was solved yesterday by an Expert who had all the replies. But as of today, as I am trying to save my topaz adjustments, I got an error. I tried it with adjust and clean2, but always failed and give me an error:
“Proc Engine: error code:-1000” I click OK and then received another error:
“Could not complete the topaz clean2 command because -Proc Engine error” I don’t know what the error is trying to imply but I really need some help here.
Answered By 25 points N/A #92922
This error occurs sometimes connected to the memory and file size of an image, to test this solution if it works. Try working on smaller images if this problem still occurs.
Has a copy of the latest version of topaz, I’ll provide you a link for you https://www.topazlabs.com/downloads
Have the amount of memory that Photoshop will use will be allowed to use down to 70%.
And after that restart your computer,
If that's still not works, please upgrade your memory by having a flash drive to be used as a virtual memory the readyboost program for windows 7 and there is a software also for Windows XP.
