I am having an unexpected error in my Grasshopper breakpoint. I am using Rhino 4.0 and my operating system is windows XP. I have uploaded a screenshot of the error I am having.
Paths must have at least one element.
Waiting for any help.
Thanks in advance.
Error seen in my Grasshopper breakpoint
If this is the first time that this happens, try restarting your computer then try it again. See if this will happen again after rebooting your machine. If you receive the same error, try doing a clean installation of the program again to clear any corrupted files that may be present in your system and to possibly restore the settings to default.
Uninstall the application then restart your computer when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics test on your machine, use disk utility applications like PC Tools Performance Toolkit, Norton SystemWorks, or Norton Utilities. Install the software again then check if this fixes the problem. You may also try upgrading it to the latest version.
