Error seen while using my Line 6 ux2 microphone
I noticed this error seen in the screenshot below, as I was using my Line 6 ux2 microphone.
I already tried to recheck all of the active mixer devices but they were all found, and the drivers seem to have no issues.
I need some help figuring this out.
Thanks in advance.
Answered By 10 points N/A #134839
The following are the possible solutions to your problem:
1. As you said that you have used line 6ux2 microphone, try to use the other lines. Just select the button beside line 6 and select other lines and check if they may be working.
2. Check the microphone whether it is working or not. You could just login to Skype and make a test call to check whether the microphone is working or not. This will let you know if there is any error with the microphone.
3. Check the drivers of the microphone device. Also check the sound drivers.
4. If the microphone also has an audio output device attached to it then make sure that you select the audio output as that device.
Hope this information helps you.
