harry white
Posted on - 02/07/2012
I’m trying to send an email message with Outlook 2010 but the error below is appearing.
I am running Windows 7 64-bit PC and MS-Office 2010. I checked on the registry settings, but it didn’t fix the issue.
And also, the same error appears when trying to send emails to third-party programs.
How can I fix this?
Microsoft Office Outlook
Either there is no default mail client or the current mail client cannot fulfill the messaging request. Please run Microsoft Outlook and set it as the default mail client.
Error sending emails to third-party programs in Outlook 2010
When you say "check the registry settings", what steps did you actually do to check the registry? Whenever you're getting this error that means Outlook has a corrupted registry key. You need to remove that and perform a Detect and Repair to fix the entry. Microsoft has an automatic fix for this particular issue, and it also tells you how to back up your registry, in case something goes wrong. Click this link to get the automatic fix: https://support.microsoft.com/en-us/help/813745/-either-there-is-no-default-mail-client-or-the-current-mail-client-can.
If that doesn't resolve the issue, try editing the registry manually. Go to Start and Run, type regedit, press ENTER. Locate this in the registry: HKEY_LOCAL_MACHINESoftwareClientsMailMicrosoft Outlook. Delete it and save. Now, look for the Repair and Detect option in Outlook. SInce you're using Outlook 2010, you need to go to Control Panel, Programs and Features. Select Microsoft 2010, click Change. Click Repair and Continue.
Let the Repair finish and check again.
You should be able to start Microsoft Outlook now without any difficulty.
Cheers!
There are two reasons that this error occur.
You have upgraded your Ms Outlook 2010 from previous version
You have made profile from automatic accounts settings.
Create a new outlook profile and import your PST data in current profile.
And if you have made profile from automatic settings then simply create new profile by manually adding accounts settings. Automatic setting is a good option for GMAIL and Hotmail. Import all your data in this profile once you have made it.
Change you default email client to Ms Outlook 2010.
Hello Harry White,
I will recommend you to visit this Techyv page because there you will get more easy techniques to fix this issue.
Outlook 2007 Error – Default Mail Client
The problem occur due to corrupted registry key. If some programs uses the Outlook Simple MAPI feature and they were unable to retrieve the necessary information from the registry. To fix this, you need to remove the corrupt registry key and then run the Detect and Repair option to rebuilt the Outlook key. Backing up uour registry is recommended to avoid any problems in the future.
1. Click Start and then Run.
2. Type Regedit in the text field and press Enter.
3. Navigate to the following key:
4. Select its subkey and Delete it.
5. Click Yes to confirm and close the Registry Editor window.
6. Launch Outlook and run the Detect and Repair option:
For Outlook 2000 and 2002, click the Detect and Repair under the Help menu.
For Outlook 2007, Click Help and click Office Diagnostics.
For Office 2010, click the Start button and go to Control Panel. Click Programs and Features and choose the Microsoft Office 2010 and click Change. Click Repair and click Continue.
7. And then, just follow the on-screen instructions to complete the repair process.
