Error in sending numerous files
As part of my job is to send numerous amounts of emails to a group of business contacts. I need this in order to accomplish my job.
In my past works I did not experience this kind of problem but now an error occurred during the process. Below this message is the detail that shows during the process.
If anyone can help me with this issue, please do comment below.
Answered By 0 points N/A #84953
There could be various problems with your emailing.
Have you checked to make sure the email addresses are valid?  If one of the addresses is invalid, it would most likely give you an error message.
You could also try using a different email format, or deleting your email program and then downloading it again.
Most likely, a bug got into your email program and isn't allowing you to do certain things with it.  You could create another account and it would probably work.
