We have a client that we recently upgraded to SharePoint Foundation and Search 2010. We tested the up gradation with Foxit PDF IFilter 2.0 since we know that it commonly runs faster and can index various PDF files. The installation for Foxit went well but we got errors in Crawl log with each PDFs. The error is stating:
Crawled (The filtering process could not load the item. This is possibly caused by an unrecognized item format or item corruption. 0x40d30)
When going back to Adobe IFilter, it works fine with manual installation and some registry modification. Does anyone know a solution for this?
Error with Sharepoint 2010 Foundation
In case the search results are not able to be filtered according to the Specific set of users, but they can be viewed by the Administrators of the site, then the possible cause of that problem is a configuration issue.
Another thing that you will need to make sure that it done is that there should be no incident of the following:
There should be no incident of fine grained permissions.
There should be no incident of target audience who have been configured on the document libraries.
You should also check that there are no lists which are stopping users from viewing the results.
So in case there are cases where the above exists, you will need to change the preferences.
-Experttechyv
