clark son
30 points
Posted on - 07/27/2012
I have received the following error.
Encountered a sharing violation while accessing C:Program FilesAcoustica Mixcraft 6mixcraft6.exe.
I quit all the other programs running and closed all folders, but it keeps showing up. Do you know what it is and how I can get rid of it?
Waiting for your suggestions.
Thanks.Â
dotties
Error showing up in spite of quitting other programs and closing folders
You need to delete Mixcraft from your computer and download it again.
If this is the first time that this happens, try restarting your computer then try it again. Open the program again after booting then see what happens. You may also try doing another clean installation on the program just to fix possible corrupted files that prevents it from working.
Uninstall the software then restart your machine when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostic test on your computer, use a disk utility application like Norton Utilities. Install the software again then see if this fixes the problem. If the problem persists, visit again the website where you downloaded the installer then check its system requirements there. It’s possible that the application is incompatible with your operating system. Download and install only the correct version for your operating system.
