I have been using Microsoft .NET framework and I updated it recently.
It was updated successfully, but now, when I start the application, I get the first error shown below:
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Could not find a part of the path C:Documents and SettingsAdministratorLocal SettingsApplication DataRevoltKV.bin'.
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue If you click Quit, the application will close immediately.
Conversion from string "" to type 'Short' is not valid.
If I load a saved file, it loads perfectly, but if I edit the saved file and then save it again, I get the second error. If I don’t change anything in the same file, even then I am met with the same error. I have also disabled my antivirus.
What should I do to get rid of the problem?
Your helpful suggestions are required please.
Error shown after updating Microsoft .NET framework
Try to install the .Net Framework uses the link given below.
There might be an error when you update. Simply uninstall the .Net framework that you installed and then try to install the one in the link and see if it will fix the error. Try also this one to fix the problem, you need to install this update to your computer http://www.microsoft.com/en-us/download/details.aspx?id=21
Remember that you need to uninstall first the .Net framework that you installed before you run this or install this. It shows also at the link the minimum requirements required before to install. Check that so you will not encounter any error with regards to compatibility.
