Error shown while deploying a picture to another laptop
I have a picture that I made for a new batch of Latitude 6420's.
Also, I could capture the K-Image and everything was running normally, but when I try to deploy the picture to another laptop, I find this error:
'Ready to copy 109734 items
failed to create item for d:$recycle.Bin: (5) Access is denied.'
The procedure was unsuccessful. What is the reason? Please help.
Regards.
Best Answer by Alexandera barb
Answered By 0 points N/A #153609
Hi Donald,
If your current procedure isn't working no issues at all. Try to copy your image to any external storage place like some HD, USB etc. Then plug your external storage device to the laptop. Copy the image and paste it where ever you want to place it. It should be working.
Thanks
Answered By 0 points N/A #153610
You should use the effective way of sending all your data which you have to other pc through mail. As transferring from external device such as usb might have some virus which is corrupting all your files. It may take more time for attaching the files and sending it via mail but it will work for you.
