Hi All,
I've been looking around the net and I hope, now I have found the relevant place to post!
For the last couple of days, I have been trying to load Sony Vegas (the latest version) on Win 7, but when I do, I get the following error:
This happens when I have completed my work and I click the render as button.
Any ideas on this please? I need your help.
Thank you.
Error shown while loading Sony Vegas (the latest version) on Win 7
Hello Rabbeca,
You will need to find a backup file on your computer and then try running it. The backup file is usually located at the same place as the project file. For instance, it can be found at myproject.veg.bak.
Another thing you should try in case the above solution does not work is holding down CTRL+SHIFT keys on your keyboard while launching Vegas. That will restore its settings to factory settings and eliminate any changes that might have been made that are causing that problem. You will also need to install the program update if the application prompts you to do that after you have restored the settings.
Carl
