Hello all,
To test my iPad, IÂ try to configure it and follow some steps to make the device ready for this, but I am getting the following error message:
"Xcode cannot find the software image to install this version"
In fact, I fixed the machine with xCode. Also, it started a few installations and then it showed the following error.
'Download the iOS Disk Image (.dmg) from the iOS Dev Center for the Apple device you are using.'
What should I do now? I need a solution. Please help me.
Thank you.Â
Error shown while testing my iPad
Hey,
What I think it's saying is that you need to download the firmware associated with the device you are using for the development software (xCode's simulator). I have two websites you can go to where the firmware downloads are hosted.
 http://www.felixbruns.de/iPod/firmware/  and
http://www.iphoneheat.com/2009/03/download-iphone-firmware-files-all-at-one-place/
If it's the simulator you are installing on your Ipad this is what you need to make it work. If you are trying to manipulate your Ipad to work with developing apps straight from the device, I can't help you there. Apple does not support mobile development of applications.Â
