Error shows on iCloud Services after updating Windows 7
Recently I made an update to my Windows 7 and today this error appeared. I don’t know how to fix this and a friend recommended to install and run a DLL fixer. I don’t know what to say about this and that’s why I would like to ask you first for a solution. Should I install and run a DLL fixer on my laptop ? Can you offer me an alternative solution that will work 100% ?
Thank you !
iCloudServices.exe – Bad Image
C:Program Files (x86)Common FilesAppleApple Application SupportYSCrashDump.DLL is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support.
OK
