Error of SQL Server 2005 Windows XP
Where can I find a suitable driver to install sql server 2005 windows xp? My computer is P-4 with 32bit, 3.33 GHz processor.
Hello.
There are no such drivers available to install sql server 2005. This software can be installed directly.
The only thing you need is sql server 2005 setup file and a compatible operating system.
Install sql server 2005 directly in to your system. There should not be a problem.
All you need is a lots of disk space.
Thank you.
Hi Brian,
This is an additional to the above solution. It's correct, you don't need to a driver to install sql server 2005 and all you need is the installer. But it won't work without installing SQL Server Management Studio Express Edition to fully use Sql Server.
https://docs.microsoft.com/en-us/sql/ssms/download-sql-server-management-studio-ssms
Hope it helps.
