randysprang
1230 points
Posted on - 06/26/2011
Hi everyone,
I am working in a law firm at the accounting department. I am working on a billing for clients. I will bill our clients for our lawyers appearance fees in court. When I was about to render the report to Excel, I met this error that TurboLaw cannot open or run Microsoft Excel.
Error Starting Microsoft Excel
TurboLaw could not start Microsoft Excel to display your document. The error was: Retrieving the COM class factory for component with CLSID {00024500-0000-0000-C000-000000000046} failed due to the following error: 80040154.
On my analysis of the error, there is a problem with my Excel. So I removed Excel and re-installed it again. I restarted my computer and do my TurboLaw again, and same error again popped up on my screen when I was on the same process.
Please help me solve this issue with TurboLaw's collaboration with Excel.
shenna22
5 points
An Error Starting Microsoft Excel
Hi good day,
You know I encountered this kind of problem during opening my Excel and some of this files being missing or corrupted.
To repair the corrupt file:
 Get your Microsoft Office CD installer and put it into the CD-ROM.
 Then the setup of the Microsoft Office will flash in your screen.
 Find repair. In these steps the corrupted file will be repaired
 Open the Microsoft Excel and it will be ok.
Thank you and have a nice day. Hope you can do it.
God bless you and regards
Shenaa22
Hi Randysprang,
     This problem also occurred to me. I solved this by following this method –
This problem is occurred for being loading malfunctioning program.
Go to the Excel menu select the tools then Add-ins- form
In the Add-Ins dialog box put out all check from the dialog box  and click on the ok
Then you need to close Excel.
Then you have to navigate your XLStart directory by using Windows Explorer from your PC.
If any files are present in the XLStart directory then you have to move the files to another location temporally.
After done above works you have to restart your computer.
After  restarting you can see that your problem will be solved.
