Error in Starting Ms Outlook
Hi, I am having problem with ms outlook. When I try to open outlook and start working, I get this error message while loading, “Cannot start Microsoft Outlook. Cannot open the outlook window. Invalid XML, the view cannot be loaded”.
I have tried to uninstall and reinstall the Outlook version 2010 but the problem persists. Please help me find a solution to the problem.
Best Answer by Alert Mariam
Answered By 0 points N/A #137188
1. First of all, ensure that your hardware is enough to boost your computer. If you a gamer, it is best to have at least 32-bit with 4GB memory or 64-bit with at least 8-16GB memory. Check if your video card is also correct.
2. Clean your desktop by removing unused shortcuts or files.
3. Perform a virus/spyware scan.
4. Run a Disk Clean up by:
     a. On My Computer, right-click it and then click on Properties. Click Disk Cleanup.
     b. Or click Start> Run and then type cleanmgr.exe on the search box and press the Enter key.
5. Remove all the unused programs on the Control Panel.
6. Run your Defragmenter to put all the same files physically closer on your HD and will boost your computer speed.
    Click Start> Run> type dfrg.msc and then click on Defrag
For additional information you can go to: https://login.microsoftonline.com/common/oauth2/authorize?client_id=3ab9b3bc-762f-4d62-82f7-7e1d653ce29f&redirect_uri=https%3a%2f%2fbusinessaccount.microsoft.com%2fCustomer%2f&response_mode=form_post&response_type=code+id_token&scope=openid+profile&state=OpenIdConnect.AuthenticationProperties%3dL0YyvrtrufX32wQFeds1IRykFtY3IC7LdpgUy56bDShameSd5vDefx8ooM9UOtGdkbgU5EHPg95a9qCYqEqctBHw9XRy97FvRyxR8HRVVY7sRVzMYU4KLE-yq-W4ADoo0QPh7OsSWuJG-0h2W0nsE2fkjSzpZvapMgBFDY8DLbI9hbbyF6c3Z8p9SNnkwCzYTUgXeZn0kpBzbVlF0DywspzsaEQ_LCQjIQ5IJ9lH4PCgG3jvJyGdAINRNqi1j_EqD7XMPg&nonce=636509934968873985.Y2M5OTg0ZTUtNjVlOS00NDM2LWI3MzctMDY4NzQ2MWNjZjJiNTRiODkzNjAtMjUxOS00Zjk3LTkyOTEtOTgyZWM3MmRmZDNk&domain_hint=&post_logout_redirect_uri=https%3a%2f%2fbusinessaccount.microsoft.com%2fCustomer&nux=1&msafed=0
Hope this helps! Cheers!
Answered By 0 points N/A #137189
you must download a new version from internet. then try to install. I hope this problemcan be solved.
