Error: Surface index out of range on rooms file
I am exercising IES version6.4.0.1 while attempting to groom tool and combine two rooms into one room, I received an error message. Does somebody know about how to solve this?
Hello Michael,
How are you? Hope you are doing well.
The problem you described looking like the model has been changed from what have you created in shading file. The mechanism is when Suncast will calculate any shading file it will create defined shading data for the same. For your case shading data is different from the original which is causing the error.
To solve this problem, simply recalculate the shading file of SunCast to take into account any model changes prior you are running any heat gain calculation.
Hope this will help.
