Error on syncing Pocket PC Windows Mobile
I am running Windows Vista and I used it to sync my Pocket PC with Windows Mobile Version 5. But when I synchronize it with my PC, I am receiving error: Windows Mobile Device Center has stopped working and then it automatically closes my desktop. Anybody knows any reason for this?
Answered By 0 points N/A #98517
Hi
Mostly this happens due to some reasons might be software version or might be credential ok you just try to follow the steps first of all connect your pocket PC if it taking too much time to connect then it will a problem with the software version of pocket PC try to upgrade your pocket pc version on your PC.  While if it connects with your pc normally then check your windows firewalls, if firewall is on the turn it off and then restart your PC once and then try to connect with your Pocket PC hope it will connect immediately if problem presists then try to upgrade your outlook version also.
Regards.
