Error – TeamViewer: A Connection Could Not Be Established TeamViewer Not Running On Partner Computer. Please Help.
I was trying to use TeamViewer. When I tried to connect to another PC, the following error occurred – TeamViewer: a connection could not be established TeamViewer not running on partner computer. How can I solve this issue?
67pc
Answered By 40 points N/A #289137
Depending upon the usage there are two solutions to your problem.
First.
  1. Close TeamViewer.
  2. Open the start menu, and from the Run dialogue box type “%appdata%” and press enter.
  3. Locate the TeamViewer folder and delete all of its contents.
  4. If you are using LAN, change the IP address of your computer.
  5. Now restart your system and try running the TeamViewer application.
Second (Windows 7 or Vista users)
  1. We need to disable the User Access Controls (UAC)
  2. From the start menu, in the run dialogue box, type “msconfig”
  3. A dialogue box appears. From the Tools tab, search for the toggle button to enable/disable UAC. Flick this button to appropriate position.
  4. Now restart your computer and try running TeamViewer.
Answered By 590495 points N/A #292760
If you are trying to connect to a remote computer using TeamViewer, make sure both your computers are connected to the internet. Once this is verified, the next thing to check is the application. To be able to connect to another computer, the TeamViewer application must be running on the other machine.
If the application is not running on the other machine, ask someone to run it to establish connection. If all conditions are met and you still have a problem, one possible cause is an unstable internet connection. If you are trying to connect during peak hours or night time, try doing it during off-peak hours to have a better internet connection.
You may also try using a portable version of TeamViewer. Download TeamViewer Portable. Follow the instructions to download and unpack. Also, if you haven’t updated yet to the latest version, download the latest from Download TeamViewer. TeamViewer is cross-platform and is available for Microsoft Windows, OS X, Linux, Chrome OS, Android, and iOS.
