The error I posted below incurs when creating Team Project in Visual Studio 11.
It seems like I do not have permissions on creating a new project.
How can I correct this error?
Please help.
TF30177: Team Project Creation Failed
New Team Project Wizard encountered the following error and could not continue.
Error
TF30170: The plugin Microsoft.ProjectCreationWizard.WorkItemTracking failed during task Queries from group WorkItemTracking.
Explanation
Plugin error text: “Could not upload queries to the Team Foundation Server.”
User Action
Contact your Team Foundation Server administrator.
Error TF30177 on Visual Studio 11
Try checking if you have a good internet connection. Try browsing some websites with your browser. If all seems well, try connecting to the Team Foundation Server.
If you still can’t connect to the server, try contacting the server administrator to kindly check if you still have permissions to the server.
It is possible that some of your rights to the server got accidentally disabled that’s why Microsoft Visual Studio 11 can not send its queries to the server.
You may also try uninstalling then reinstalling Microsoft Visual Studio to restore its settings back to factory default.
After reinstalling it, try creating a project again and see if it can connect now to the server. You may also try checking your computer for any possible errors.
Use a disk utility application to check the system.
