Error: “There was a problem sending the command to the program”
Posted on - 07/28/2011
When I right-click on a folder and click the "Search" option I got this error message. Also when I use the Quick Launch bar and click the "Show Desktop" It also show same error. "There was a problem sending the command to the program".
Does anyone here have the same problem as mine? Let me know if you found solution to this problem.
