The title bar says "Windows No Disk". The body of the message is always "Exception Processing Message
c0000013 Parameters 75b6bf9c 4 75b6bf9c 75b6bf9c".
It goes away if I hit Cancel twice, but it is a botheration.
I have tried the update service, but it persists.
Any suggestions?
Error in the title bar says ‘Windows No Disk’
The cause of the error that you are getting right now is usually a program known as dit.exe that is usually installed by some card reader software in order to let you name the drives as well as to make it possible for the drives to have individual icons. This program usually runs on startup. You should do the following;
Test to find out if it is that program that is causing the problems.
After that you should run msconfig and in case it appears in your startup list you should disable it and then restart it.
After that you can delete dit.exe from your windows folder.
Make sure that you also do a registry sweep in order to remove any dit.exe entries
Carl
