I am getting some nonsense error in Total Command which is an access violation. How can I remove this application error? Any idea would be greatly appreciated. I would be grateful to you.
Exception EAccessViolation in module TOTALCMD.EXE at 03148614.
Access violation at address 03549854.Read of address 03549854.
Error in Total Command which is an access violation
Collleen
This error violation that you are experiencing is caused by system failure or windows files damage. You can repair your windows for it to restore the damaged files.
Another way is if you have a restore point. Note “If you are going to use windows open system restore try to make sure that all your important files are backed up.”
Steps on how to use system restore:
1. Window key + r or hit the window button on your desktop.
2. Type in windows restore
3. Choose Restore you Computer or Re install windows
4. A tab will open and click open windows restore.
5. Click next then choose a restore point
