An error of Trinity core server
Hi everybody,
I just compile Trinity core server. After that I try to run my server, but here I got an error message via worldserver.exe. This message is attached below.
I want to get rid of this problem. Any tips?
authserver.exe- Application Error
The application was unable to start correctly (0xc00000lb). Click OK to close the application.
OK
Answered By 20 points N/A #110505
Hey Howel Dinh,
The reason behind this error is your out of dated drivers. What you need to is just to update your out of dated drivers and you will not face this error message again.
Make sure that your DirectX is updated. You have to install .net framework. After installing it you have to upgrade it .net framework 3.5.
You also have to make sure that you have installed the DirectX Redist for 2009. I am going to add a link here for you. You just have to click that link and you can install the DirectX Redist. Here is the Link.
After that you have to install Microsoft DirectX® End-User Runtime. After upgrading all these components you will not face problem.
