Meriline
Posted on - 10/21/2011
Dear friends,
The following compilation error appears in my system. Have you faced such problem? Since I don't have any idea and have little experience with PC, I couldn't solve the problem. If you know the solution please let me know.
Warning
ERROR: Trying to compile at 0.LR=80109614
Your,
Meriline
Hi Merline!
I hope you are doing fine. I am also wondering why that error appeared on your PC. Are you trying to open a file and play games? That is just a random error and may not happen every time.
Try to disable panic handlers and see if you can bypass that kind of error. Panic handlers tend to crash the emulator when an error happens, but disabling will allow you to bypass such error without crashing. I'll be glad if you let me know what happened after you try to use my solution. Have a great day to you.
Nathan
Dear Merline,
I am sure you are trying to play a game on your PC and these kinds of errors occur only then.
There is some problem with some of the files of the game installed.
You need to uninstall (control panel/programs/uninstalling program/click right on mouse on game option/uninstall) the game and install it again to check if the error occurs again.
If not then you need to talk to your game service provider.
