Error trying to publish a DWF
Hey,
Has anyone had a similar problem to this one: while trying to publish a DWF drawing I got an error message that goes like this:
“Error
The current operation encountered problems processing one or more sheets and the plot job has been canceled.
To successfully complete this operation, remove any unplottable sheets from the job prior to running it.
For a summary of which sheets are unplottable, refer to the plot log file.”
I’m using Windows XP,and the problem seems to occur in the moment when I try to print the sheet or to save it (to be more specific: when there’s a need of another window opening during the process).
I hope I gave you enough details to go on, and any help would mean a lot to me.
Thanks very much in advance.
