Hello and Good day,
I have a very big problem with Visual studio. I have 5 files projects using Visual Studio. Those projects have references which open a MS Access database file connection. After finishing it, I call a function from one of my projects, it works good, but when I tried to run this particular project of mine, it says an error that my local machine was not available. So guys, how can I solve this Visual Studio Oledb problem.
Thank you.
An error for a unavailable Visual Studio Oledb
Users get this error when they are missing some of the libraries which are needed to successfully start work with databases. In order to fix this issue, you need to download and install those libraries. To download them, click on this link:
http://forumarray.com/visual-studio-error-creating-control-request-not-available-520249
The download should begin automatically, but if it doesn't, just click on “Download now.” After the download is complete, run the downloaded installer and you shouldn't see this error anymore. Regards.
