Error in uninstalling QuickTime 7.7.1
I was trying to uninstall QuickTime newest version which is version 7.7.1 but I got a “Fatal error during installation” error.
How can I fix it?
How can I fix it?
I found a guide for you that will help you solve the problem that you are encountering and please follow the procedures thoroughly and wise fully here is the link for the guide that will help you solve the problem that you are encountering
Here is the link for the support on the problem that you are having https://support.microsoft.com/en-us/help/2438651/how-to-troubleshoot-windows-installer-errors
If the guide will not help you, please install and registry fixer and cleaner maybe some files has just messed up I would recommend you Ccleaner (there is a free version of this one)
Please inform me if this problem still occurs I will try to find out what’s really happening
Hi alden ,
It seems you already have a quicktime so if you have errors please try uninstalling it first before trying to update it . Uninstall it and download it from a genuine sites make sure viruses don't come into it now download it and install it .
Hope that works for you .
If it didn't . Just try cleaning your temp folder maybe the installation cant rewrite stuffs in that folder just go to run either by entering through start or press win key + r for shortcut now delete all the contents in it don't worry it wont harm your PC now ignore any files that didn't gets deleted now try my above steps again and give a small system restart.
Hope that solves your issue .
