Error: Unlocker Error Debug Privileges On Windows.
Recently I had installed a software to delete files completely and cleanly from my computer. While using it, I get the error – unlocker error debug privileges and the files is not deleted. Please help.
Answered By 20 points N/A #288366
qa-featured 47
After analyzing your problem, it seems that your have issue with the administrative rights for your computer. You can solve your problem in two ways.
• Log out of your PC. Now log in again as admin and use the software. This must work. Now, go to control panel and set up user rights for the user you were previously logged in as. Make sure the previous user had rights to use third-party apps and also delete files.
If the above solution does not work,
• Go to the ‘Administrative Tools’ of control panel. From here, select ‘Local Security Policy’ and select the ‘Local Policies’ directory. Click on ‘User Rights Assignment.’ Open the ‘Local security policy’ dialogue box and create or add a new user. Now enter your username.
Answered By 590495 points N/A #315589
If the error mentioned something about “privilege”, try launching the program as admin to grant full administrative privileges. Right-click the application and select “Run as administrator”. If this doesn’t work, try to uninstall and reinstall the program. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select the affected program among the applications and click “Uninstall”.
Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo Uninstaller then install the program back. Try also updating the program to the latest version.
