I’m having just installed Internet Explorer 7, I have the OS Windows Vista. With the new version of IE, I had many problem for example In Internet Explorer's default setting, a small warning icon appears in the status bar like the one pictured left.
Double – click this icon to display a window with the complete error message.
The complete error message looks something like this:
Problems with this Web page might prevent it from being displayed properly or functioning properly. In the future, you can display this message by double – clicking the warning icon displayed in the status bar.
OK Hide Details
Line: 71
Char: 1
Error: Object expected
Code: 0
lee hung
75 points
Error using internet explorer 7
Hi Nadia,
I suspect that the new version of internet explorer that you have installed might be having compatibility problems with the vista operating system, so I may advice that you stick to the one that you were using before that error started occurring. To go back to the old version, you can just go to the control panel and install the one your system, look for the set up of the old version and install it.
Otherwise you can try uninstalling and installing internet explorer again, may it is an error due to missing or corrupt registry settings which re-installing might fix.
Hope this helps.
____
Lee Hung.
Hi!
Here I am to provide you list of steps of solution that might assist you:
1. First of all, this problem might caused by lack of Javascript. You should download the latest one.
2. Then, change the settings in your preferred browser by clicking on Tool button.
3. There will be Internet Option. Select it and click on Security tab on top, next choose Custom Level.
4. Beware, you must turn off your internet security control.
5. Choose OK.
6. Choose Yes when asked about your confirmation.
7. Choose Advance. Drag the line bar to the bottom.
8. Tick on Empty Temporary Internet Files.
9. Choose Settings.
10. Always to pull out the circles.
11. Click OK.
12. Select Internet Explorer 7.
13. Right click on desktop, choose Start without ad-ons.
14. Select Internet Explorer 7.
If you are using Microsoft Internet Explorer, try updating your browser. If you have Windows XP, download Microsoft Internet Explorer 8 for XP. This is the latest and last version to support Microsoft Windows XP. If you have Windows Vista, you can download and update to the following:
If you have Windows 7, Windows 8.1, or Windows 10, go to Microsoft Internet Explorer Downloads to download the latest update for your browser. See if this works. If this doesn’t fix the problem, just use a different browser like Mozilla Firefox, Google Chrome, Opera, or SeaMonkey. If you have Windows 8, you should update to Windows 8.1 to update Microsoft Internet Explorer to the latest.
