Error in Using the Rainlendar Pro Version 2.9(b111)
Hello friends
I have recently started using rainlendar, the calendar program for windows. I am using the rainlendar pro version 2.9 (b111). I tried to sync it with the Google calendar but unfortunately I failed. Instead I got the following message on my screen that read:
Gooqle Error (Gooqle)!Unable to download the calendars.
Server returned result: (0) 400 Bad Request.
Inconsistent repeating query parameter
start-min
The screenshot of the error message is as follows:
What should I do to make rainlendar functional? Your helpful suggestions are required to fix the problem.
Looking forward to your suggestions
Kind regards
Harry
