Alex Clark
Posted on - 12/11/2011
Hello, I am using Webcam max 7.1.7.2 latest version and also FME 3.1 to flow, however I found some error. I am using 250 or 300 kbps for the broadcast bitrate and FME is on automatic mode but when I click access and begin to switch to flow 2500 kbps and this was a big trouble because it could not flow like that. The image not appears on the player and does not have a high upload. Please help to solve this issue.
Error using Webcam max 7.1.7.2
Have you tried changing the bit rate of the webcam in the webcam settings? Maybe if your alter the bit rate and increase it the upload speed will increase too. If it does not then the webcam has been designed to support a maximum upload speed of 300 kpbs and therefore it cannot exceed that. You may try getting another alternative webcam application and see if it can give the best functionality when it comes to the speed at which the files are uploaded. My suggestion as to the webcam you may try is YouCam. It is the fast webcam that I have come across and it runs on quite a number of platforms, and I am hoping that it will run on yours too.
Regards
Thompson Locker
