Error in Validating Vault 2011 to 2012 Migration
Hi.
I am in need of help in my Vault 2012 migration. I tried to migrate from Vault 2011 to 2012 but beforehand I also tried to backup the Vault. I log in as the Administrator and then select the Tools and then Backup. When all the process is done, it starts the validation but when done with it I am now facing an error "Failed to check pending changes from workgroup AUTODESKAUTODESKVAULT. Error a network related or instance specific error occurred while establishing a connection to SQLServer. The server was not found or was not accessible. Verify that the instance name is correct and that SQL server is configured to allow remote connections. (provider: SQL Network Interfaces, error : 26-error locating server/Instance Specified)" What is the solution for the issue? Any help will be appreciated. Thanks.
