ERROR: The version of SigmaXL requires a 64-bit version of MS Office
The version of Sigma XL requires a 64-bit version of MS Office. Please contact Support@SigmaXL.com to request the 32-Bit version of Sigma XL.
SigmaXL Installer Information
This version of SIgmaXL requires a 64BIt version of MS Office. Please contact Support@SigmaXL.com to request the 32Bit version of SigmaXL.
OK
Best Answer by Nicke Baker
Answered By 0 points N/A #160651
Hello Aimusthave,
That is an error due to a compatibility issue.  It seems like you are trying to install a 64 bit version of SigmaXL while on your computer you have installed a 32 bit of version of MS Office. The two are not compatible, and therefore you will need to get a 32 bit version of SigmaXL too for it to work properly.
Nicke
Answered By 0 points N/A #160653
The message says there is a compatibility problem, because your Microsoft Office is a 32-bit version while the SigmaXL is a 64-bit version. You can solve this by acquiring a SigmaXL 32-bit and everything will be ok.
Answered By 590495 points N/A #160655
That error was triggered when you install SigmaXL because the version of Microsoft Office currently installed on your computer is 32-bit and the version of SigmaXL you are installing is 64-bit. That would really create a conflict because they both support different system architectures. To fix your problem, if you cannot replace your existing Microsoft Office with a 64-bit edition, you need to download the 32-bit version of SigmaXL.
SigmaXL is a statistical and graphical add-in for Office Excel. It is a commonly used tool for graphical and statistical data analysis and is frequently used in Six Sigma implementation and training. SigmaXL has been used in scientific and medical research articles. Cynthia Cumby and John Noguera developed SigmaXL in 1997 and distributed by a privately owned company called SigmaXL Inc. located in Kitchener, Ontario, Canada.
To download the latest version, go to SigmaXL 30 Day Free Trial and fill out the form. In the Comments field, indicate that you need the 32-bit edition of SigmaXL because you have 32-bit Microsoft Office.
