Error in Virtual PC 2007
Hi friends,
I have recently started using OFM software "Total Commander" in the virtual PC which I have created with the Microsoft Virtual PC v.6.0.192.0 2007. I am using windows XP sp3 32 bit on both my physical computer and the virtual PC.
Folder C:_Temp is placed in my physical PC whereas on the PC it is named as disk Z.
My problem is that when I try to copy something from Z to the virtual PC, I receive the following error:
Temp4.zip
CRC error, archive file corrupted!
OK
How can I fix it up?
Can anyone please guide me to get over the problem? I'll be grateful.
Regards
Bill
