An error was found parsing the command line.
Second life error: My software with the name of Second Life is not running. Suggest me something to work it properly and also let me know why this error comes and what the resolutions steps used are.
Hi Michael,
I believe you had Kitely Plugin for Mac v1.0.0 installed.
The issue you describe here was a result of a bug that was fixed in Kitely Plugin v1.1.0.
I recommend you:
1. Uninstall your existing Kitely Plugin.
3. Install the Kitely Plugin V1.1.0 you just downloaded.
4. Try entering your world again.
I hope this will solve your problem.
Please let me know if this solved your problem.
Thank You.
If you have a problem with “Second Life”, try downloading the latest Second Life Viewer. The latest version at the moment, Second Life Viewer 6.2.3.527758, supports Windows 7, Windows 8.x, and Windows 10.
It requires Intel Pentium 4, Pentium M, or equivalent AMD Athlon 64 or faster processor with SSE2 support; 1 GB RAM; 1024 x 768 pixels screen resolution; NVIDIA GeForce 6600, ATI Radeon 9500, Intel 945 chipset, or better video card; and cable or DSL internet connection. Second Life is not compatible with the following internet connections: dial-up, satellite, and several wireless internet services.
The following video cards are not compatible with Second Life:
“Second Life” is an online virtual world developed and owned by Linden Lab, a San Francisco-based firm, launched on June 23, 2003. It had approximately one million regular users in 2013 and between 800,000 and 900,000 active users at the end of 2017.
Notifications
