I am getting an error message when I attempt to burn a media file onto a DVD+RW, a re-writable DVD, using Nero software. The error would say "Burning Process Failed". Now I need help on how to burn the files using a DVD+RW. How can I get rid of this error message so I can continue to burn the files? Any suggestions would be a great help. Thank yo
Error when burning files to a DVD-RW while using Nero
steps on how to burn your files using a DVD+RW with Nero:
first, insert a BLANK DVD-RW (rewritable DVD) disc into your computer's DVD burner drive.
next, click menu on the lower left corner then click all programs and then you could see "burn a DVD or data DVD". Click it then select  "NERO STARTSMART" to open your Nero software.
Then select the DVD option seen at the top of the Nero software screen which is from the pull down menu button then use your mouse to hover over the "Data" icon.
Under the Data icon, click the MAKE DATA DVD link to open the Nero express screen then click ADD to open the SELECT FILES AND FOLDERS window.
Then look for the media file that you wanted to burn into your DVD-RW and select it. After which click ADD button. You will be able to see the file/s you've chosen in the DISC CONTENT screen of the Nero Express window and then click on FINISH button  when you've successfully loaded all your files.
Then click NEXT button to reach the FINAL BURN SETTINGS screen and select 8x as your burning speed, if there is any, and then click BURN to start burning.
A dialog box saying BURN PROCESS COMPLETED SUCCESSFULLY will appear that the burning has been done.
Click then the OK button and the DVD-RW will automatically eject from your computer's DVD burner drive.
