I freshly installed Yahoo messenger on my Windows XP machine. Installation was successful but I encountered some issues. When I try to click the email notification on the system tray, I got this error message also  same as when I click the View Profile option under the menu on Yahoo messenger: Â
"This file does not have a program associated with it for performing this action. Create an association in the Folder Options control panel".
Error: When clicking system tray icon and View Profile in Yahoo messenger
We'll begin with Windows Explorer:
Open up Windows Explorer. (The Windows Key + E, on a significant number of consoles.)
Recognize any document with the PPS expansion. Case in point somefile.pps.
Right-click on the filename, and select Open With ….
Yet if the PowerPoint or PowerPoint Viewer is even now cataloged don't click on it. As an alternate, select Choose Program at the lowest part of the record that would be shown.
In the coming about dialog box you ought to identify PowerPoint, or PowerPoint Viewer, and click on that.
Click the case marked "Always utilize the chose project to open this sort of record".
Press OK.
This built your determination lasting. PPS records can now be opened with the system you've chosen.
This would be enough. See assuming that it determines your situation. In the event that not, we possess a more put to construct a comparative alteration. Yet this one's even geekier.
First and foremost, you'll ought to find "powerpnt.exe" (PowerPoint), or "pptveiw.exe" (PowerPoint Viewer) on your hard circle. This fluctuates dependent upon the rendition you might have. For Office 2003, with a default introduce, I found them at:
"C:Program FilesMicrosoft OfficeOFFICE11POWERPNT.EXE"
"C:Program FilesMicrosoft OfficePowerPoint ViewerPPTVIEW.EXE"
The quotes are noteworthy being as how there's a space in the index name. The promotion as a matter of fact doesn't matter. Recollect which one you have, we'll require it in a second.
Now we go, as the slip inform prescribed, to Control Panel.
In Control Panel, twofold click on Folder Options.
Click on the File Types tab.
In the Registered File Types catalog, parchment down until you spot the PPS passage and click on that. It might as well, as of right now, tell you in the Details area that it "opens with: " PowerPoint or PowerPoint viewer.
Click on the Advanced catch.
For a PowerPoint document, one of the Actions posted ought to be Show.
Since "Show" exists, click on it, click on Set Default, and click on Edit….
In the Application utilized to perform activity: drop in the full way to either PowerPoint, or PowerPoint Viewer that you found above, or utilize the peruse catch to identify them again. Don't hit OK actually yet.
For PowerPoint, when that full way name unite a space accompanied by: /s "%1". For PowerPoint Viewer, do the same, just without the /s.
OK your direction once more out.
In the event that "Show" didn't exist, click the New catch, sort Show in the Action field, and in the Application utilized to perform movement field, drop in the full way to either PowerPoint, or PowerPoint Viewer that you found above, or utilize the scan bind to recognize them again. Don't hit OK unequivocally yet.
Hello
To resolve this issue, perform the following step. The instruction below apply on Internet Explorer 6
Click start,run and type control INETCPL .CPL
Click programs tab in the resulting dialog
choose reset web settings and closed the dialog.
If that doesn't help you regsvr32 /ishdocvw.dll.
Once you done that you need to make Internet explorer your default browser by clicking on start select setting
Click control panel click on internet option Click the program tab click on internet explorer
Thanks
Hi Georger Martin,
I recommend you to reinstall your Yahoo messenger on your Windows. First you need to find property version of Yahoo messenger for Windows XP. That is going to help you 100%. If that does not help you, u can always install new version of Windows. That is all my help that you are going to get.
Goodbye.
