My new Android tablet shows some kind of verification error when I try to connect it to wi-fi. I tried restarting it but that didn't help. Can you tell me what the problem here can be. I have one more device connected successfully to the same wi-fi, but this device doesn't work.
Error when connecting tablet to wi-fi
Hi Alfredo,
The authentication code error you encounter while trying to connect to WiFi says that you need to verify the password of the WiFi to be able to successfully connect. Once you ensure that the password you input is correct, that will be the time that you can connect to the internet using your android tablet. But, if it's not solved, it's something to do with the network SSID. You need to check also that the network SSID is set to visible so that you can successfully connect to the network. To know more about modifying SSID, kindly refer to the link below.Â
How to modify network SSID – This link will guide you through the online tutorial that discuss the step-by-step process on how to modify network SSID to be visible or hidden.
Ware
