Error when double clicking on glovebox software
I am getting an error here when I double click on glovebox software. It pops a message box with YES and NO option.
When I click on YES sometimes it runs correctly and most of the time it does not run and pops up another error message box in bottom.
I am getting this problem from last two months.
Any help would be appreciated.
Error : Single instance Error
The application encountered problem while attempting to determine if any other instance of the software were running.
The following problem were encountered:
Failed to open shared memory-failed to release mutex
Do you want to open the application anyway?
If another instance open, the glove may fail to connect properly.
Exception thrown
Creating a view of shared memory failed.
At GloveBox.GloveBoxMain.writeHandle(InPtr hWindow)
At GloveBox.GloveBoxMain.OnHandleCreated(EventArgs e)
Application Exiting.
