Error when I am trying to run the Windows 7 Upgrade CD
I am getting this error when I am trying to run the Windows 7 Upgrade CD:
"This installation disc isn't compatible with your version of windows. To upgrade, you need the correct installation disc. For more information, check your computer's system information. To install a new copy of Windows, restart (boot) your computer using the installation disc and then select custom (advanced)."
Thank you in advance for your help!
Windows Setup
The installation disc isn’t compatible with your version of Windows. To
check your computer’s system information. To install a new copy of
Windows, restart (boot) your computer using the installation disc, and
then select Custom (advanced).
