An error when I play old spider solitaire on win 7.
Asked By 460 points N/A Posted on -
An error when I play old spider solitaire on win 7. There are some times that I get bored and play with those built in games in my windows 7 os desktop computer. The last time I tried to open the solitaire game it says unable to open file. I need some ways to fix those error.
Benjamin.
Answered By 0 points N/A #92384
Hi there,
When your computer says unable to open file, to be more specific unable to open your spider solitaire means that it comes with these common problems,
·         Your computer is full of malware,
·         Your computer is full of viruses,
·         Or you just deleted some file that you are not supposed to delete.
The best way to solve your problems is to just protect your PC with the best antivirus you’ve got or make a restoration point for your System restore so that you can restore your PC to the way it was.
