Hello Guys,
I met this error when I was trying to update Malware bytes scan (the free version) and run a on my computer. The error contained the message below.
I also added a screenshot of the error to the post. “PROGRAM_ERROR_UPDATING”
Malwarebytes Ariti-Maiware
An error has occurred. Please report this issue to our support team (include the content of all error message(s) and code(s) in your
submission).
PROGRAM_ERROR_UPDATING (0,0, Host not found)
OK
Error when I was trying to update Malwarebytes scan
Are you using a router? If so you can try to reset your router if this problem still persists. Just pull the power cord off for maybe 30 seconds then plug it back in. Wait for the router's lights to return to their normal state and when your internet connection is up you can try updating your Malware bytes again.
Ammelia Jesse
You have this kind of problem for your internet connection or your router connection. You have to reset your internet or router connection. Then you have to turn on the router connection after 2-3 min. I think, then your problem will be solved by following these step.
Best regards,
Brandy Gilmore
