Error when installing and using Norton Utilities 15
I wanted to activate the real-time disk defragmenter but I can’t proceed with this error message:
Error:
Norton Utilities SpeedDisk:
Real – time defragmentation
Plugin driver is not registerd.Please try to reinstall application or contact Symantec support if this problem continue. Tried re-installing but didn’t work out.
Any help over here please.
Answered By 0 points N/A #144626
It seems you are not using the premium version. This means you are using a trial version and that you have a product that is out of date. Of the updates are regular then this problem should not arise. Once you download plug-in then you shall delete it completely. The main reason to the error is that you need a genuine any fresh copy of software updated. This software gets registered on an updated version. It is a risk o use an unregistered version. Thus all that you need to do is given above and that any more help required will be accepted gladly. Thanks.
