TGraham
Posted on - 10/19/2011
I was installing Autodesk Maya 2011 on XP when I got this error (see below).Â
I tried uninstalling the software but the same thing happened, same error message.Â
I then tried removing the software but I seem can’t do it.Â
Can the experts here help me resolve the problem?Â
Thanks!
Autodesk Maya 2011 64-bit
               1: 5 2: adlmPITRemoveProductInformation failed. 3: 12
Error when installing Autodesk Maya 2011
It seems that you have installed a 64 bit Maya software to a 32 bit computer. You should have checked your computer before installing any software.
Solution 1:
Download the Autodesk Maya software that is running on 32 bit computers and then install it on your computer. It should work perfectly fine as long as you have all the necessary hardware and software requirements running on your computer.
Solution 2:
Choose a different type of program that has the same function as the Autodesk Maya. Maya is sold genuinely and it is expensive and eats a lot of your resources while running. It has a trial version for a limited time only. Try using Blender, its free and open source and uses little of your resources.
