Hello, I need to solve a very crucial problem; I am unable to install Daemon Tools Pro Advanced version in fact the latest version from the official site. Whenever I tried to install, it shows error that says something about "verify license" window and then an error message appeared on the screen: it's Trail version that I am trying to install.
Kindly help me out from this error. For your information, my OS is Windows 7 32-bit.
Error:
Activation checking error.License activation is required for product usage.
Error when installing Daemon Tools Pro Advanced version
Hello
As you can see that this error is due to activation process. you need to make sure that you have a working internet connection so that it may contact with the server to get the license details and verify your license.
There are two reasons which are behind the installation process.
1- Internet Connection
2-Windows host file
Make sure your internet connection has no connectivity issue. If there is any issue then please correct it.
Access the host file and check that there is no blockage to the server connectivity.
You can access the host file at this location in your windows directory.
c:windowssystem32etchosts
Hello John,
As you can see from the error message, the activation process needs to run but it is not able to do, and therefore you will need to troubleshoot the issues that are causing that.
Daemon Tools Pro normally needs internet connection to run the activation, and therefore you will need to make sure that you are connected to the internet and the run the activation process.
In case the internet is too slow, the activation may fail too and therefore you will need to resolve any issues that may be causing slow internet connection speed on your computer.
Hope this helps.
Carl
