Error when installing reQall for Outlook 1.2.0
I have initiated an installation of reQall for Outlook 1.2.0 and faced the message that says no supported Outlook is installed [Outlook 2010 beta (32/64 bit), 2007, 2003, 2002 or 2000]
Let me start by telling you that I have Outlook 2010 beta installed and functional.
Is this what’s causing the error?Â
What should be done now?
Thanks for any help.
reQall for Outlook 1.2.0 Setup
No supported Outlook is installed [Outlook 2010 beta (32/64 bit), 2007, 2003, 2002 or 2000]
OK
